i am using 2.11.1 rc1
it seems that i cant switch off tiling from dispalcemet
and if i confine the displaced material with a polygon selection tag an annoying line appears
is there a way to fix this problem? THX
displacement problem
what do you see when you try this scene?
- Attachments
- disp.zip
- (112.36 KiB) Downloaded 213 times
- turtles123
i don't have problems with your file, i have problems when i use image texture.
the other problem i have is that the displace is always tiling, how can i avoid that?
theoretically my sample and your scene is same. you should know c4d shaders are converted to images. only difference is color depth between two sample. so float images is looking better. also any settings of image does not seems as working.
all of these issues which are not related with plugin
- turtles123
pls try to check this scene. two planes side by side one with displacement the other not.
is not clear my last message? I mean that should try 16 or 32 bit images
