OctaneRender™ for Blender 2.06 - 6.4 Linux [OBSOLETE]
The Linux version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Fixed bug: crashed in some cases when adding new image texture during Live-Render active.
  • Reworked translation of modified geometry (to address the bug reported by aLeXXtoR).
Installation:
- If you need to run the OctaneServer - run it as daemon:
# OctaneServer &
DOWNLOAD
Blender Octane Edition - v6.4 Linux (108MB autoinstaller file)
kaiwas
happens when change UV
grimm
kaiwas - looks like you have the nodes setup incorrectly, I would double check and make sure that the pins you are connecting are correct for the node you are using.
Jimstar - Unfortunately Blender crashed when I was rendering an animation. Here is the error file output:
# Blender 2.72 (sub 0), Commit date: 1970-01-01 00:00, Hash unknown
bpy.context.space_data.viewport_shade = 'RENDERED'  # Property
bpy.context.space_data.viewport_shade = 'TEXTURED'  # Property
bpy.context.scene.octane.kernel_type = '2'  # Property
bpy.context.scene.render.resolution_percentage = 25  # Property
# backtrace
./blender() [0x9e14d5]
/lib/x86_64-linux-gnu/libc.so.6(+0x36c30) [0x7fecde63dc30]
./blender(RE_engine_get_current_tiles+0x4c) [0xd16c2c]
./blender(draw_image_main+0x1ea) [0xa2b42a]
./blender() [0xa26c99]
./blender(ED_region_do_draw+0x88e) [0xc8457e]
./blender(wm_draw_update+0x5d1) [0x9e5bb1]
./blender(WM_main+0x28) [0x9e1628]
./blender(main+0xd73) [0x9df643]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5) [0x7fecde628ec5]
./blender() [0x9de6ed]
Here is the .blend file, it's simple.
path.blend
(1.19 MiB) Downloaded 272 times
It got to frame 55 before it crashed.
Jason
kaiwas
using the same materials that worked correctly in version 2.06 - 6.0
if there have been changes in the settings of the nodes - I would like to know about it
afecelis
having library problems in ubuntu 14.04 again, this time with libGLEW 1.5:
error while loading shared libraries: libGLEW.so.1.5: cannot open shared object file: No such file or directory
Previous version worked just fine :(
Win10 Pro | Geforce GTX1070 8gb Vram X2 (display/render) | Intel Core I7 4770K 3.5GHz | 32GB DDR3 1600 Ram |Nvidia 378.78 drivers | Cuda 8.0 | Blender/Modo/Sketchup
Synthercat
afecelis wrote:having library problems in ubuntu 14.04 again, this time with liblew1.5:
I had the same... I think I sloved it with soft link... yes that must be it I linked libGLEW.so.1.10 if I remember corect
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
afecelis
Hi Synthercat, could you please share the command you used for the softlink? ;)
regards,
Alvaro
NM, I got it. ;) I just needed to "sudo locate" where the library was to set the paths properly. It's working fine now with this command:
sudo ln -s /usr/lib/x86_64-linux-gnu/libGLEW.so.1.10 /usr/lib/x86_64-linux-gnu/libGLEW.so.1.5
Thanks for pointing me in the right direction. :D
eMirage
please how to install or run this in Ubuntu ?, I tried with sh command but it doesn't work
I'm using Ubuntu 14.04
thanks.
Synthercat
Check out page 3 post 2 here :
http://render.otoy.com/forum/viewtopic. ... #page-body
I wrote a guide from Mint 17 (14.04), it should work for Ubuntu too
eMirage
Synthercat wrote:Check out page 3 post 2 here :
thanks I'll check this.
Return to “Blender”
