Rendering more than 3000 passes?
Carrara (Integrated Plugin developed by Sighman)
Jonstark
Is there a way to render more than the 3000 default passes? Got a pretty darkly lit scene with lots of dim lighting, and even after 3000 passes still got a fair bit of noise/fireflies. Is there a way to change the default so it does more passes? Just curious...
Sighman
You can.set Max Samples in the Kernel settings.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
Jonstark
Thanks!
Tugpsx
Trick with dark scene is also to render at larger rez than needed and reduce size to help with fireflies.
Return to “Carrara”
