Rendering more than 3000 passes?
Is there a way to render more than the 3000 default passes? Got a pretty darkly lit scene with lots of dim lighting, and even after 3000 passes still got a fair bit of noise/fireflies. Is there a way to change the default so it does more passes? Just curious...
Trick with dark scene is also to render at larger rez than needed and reduce size to help with fireflies.
