Hello,
Smoothing problem with native SubPach modeling LW ...
Problème de lissage sur des modélisation natif SubPach de LW
Do you have the "smoothing" parameter enabled in the native LightWave surface panel?
Also perhaps you can have a precision problem if your scene too big or too small. Change the "ray epsiolon" parameter in the kernel node that you are using and set it to 0.001 or 0.01 to see what happens.
Of course, if you want to send to me the scene, I could test it here.
