hello,
I can't find the way to render all passes simultanously .
does anybody know how to do that?
render passes
Just enable (ie. tick the checkbox) all the passes, and they will render. If using the latest release, the render statistics will tell you which pass is currently being rendered.I can't find the way to render all passes simultanously .
You will need to be on version 2.10 or 2.11 for render passes. Suggest you install the version at http://render.otoy.com/forum/viewtopic.php?f=34&t=42581.
The manual has some info on render passes at http://render.otoy.com/manuals/Modo/?page_id=1058.
I've just install V 2.11 and... I think i'm gonna get crazy! the "about Octane..." says I m using v2.0 an I don't have the same window for render passes than in the manual. See image below and the link to the manual
Hi Simsen - render passes are changing with each Octane release at the moment - but once they are finalised I will update the manual to reflect the actual passes. Until then the screenshots in the manual and the plugin may not exactly match. And I will change the "About" bitmap to read "Octane 2" rather than "Octane 2.0". You can see the actual plugin version number at the bottom of the Setup panel, and in the Modo->System->Kit Toggle Enable menu.
Hi Simsen. Tick the render pass(es) you want to render in the Render Passes panel, then choose the render pass you want displayed in the Viewport from the "Select Viewport Render Pass" dropdown box.
