PMC Kernel will not load.
Which version of Octane & plugin?
I can't reproduce the symptoms here in any of the projects I've loaded.
Using LW 11.6.3 (on Windows 7 x64), Octane 2.06 and plugin v 2.6.4
Asus 780 GTX Direct CU II OC (3Gb), Driver release 347.88
Asus P9X79 Pro, 64Gb DDR3, i7 4930K @ 4.5GHz
Windows 7 x64, Lightwave3D 2015, Octane & LW plugin
Are you using a GTX 970 or 980? PMC is not supported on those yet, but will be with the next release.mikefrisk wrote:IPR or F9 render, it sticks on "Updating Scene In GPUs", nothing ever happens. But if i switch to any other kernel option it works swimmingly. Any thoughts?
abstrax wrote:Are you using a GTX 970 or 980? PMC is not supported on those yet, but will be with the next release.mikefrisk wrote:IPR or F9 render, it sticks on "Updating Scene In GPUs", nothing ever happens. But if i switch to any other kernel option it works swimmingly. Any thoughts?
That's it! I have two GTX 970's.
Curious about these cards comparing render speeds.
http://render.otoy.com/forum/viewtopic. ... rk#p195478
Please try the lightwave grass scene with your cards and post the m/s.
I notice a very big issue with maxwell based cards and displacements. The slowdown is more than 10x with scenes that have displacements using maxwell based cards
