Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
- New 2.11 engine.
- Fixed mix material UI bug (connecting the materials to attributes using the checker-button).
- Fixed reshapable proxy motion blur bug.
- New "Distributed tracing" attribute in passes settings.
- New "Highlight compression" attribute in imager node.
- New attributes in "Color correction" texture: Hue, Saturation and Contrast. Brightness scale and black level are removed from this texture.
- New "Static noise" attribute in direct lighting and path tracing kernels.
DOWNLOAD
OctaneRender for Maya 2.11 - 5.3 (31.8MB autoinstaller file)
OctaneRender for Maya 2.11 - 5.3 Demo (30.0MB autoinstaller file)
Yours,
The OctaneRender™ Team.
