bug object cloner on Octane render 2.0.6.1
r4dn
Hi
I just noticed a problem with the object cloner on Octane render 2.0.6.1
rendering live preview works and as soon as we go through the octane engine for HD rendering, cloner works more.
The cloned object does not appear in the rendered.
someone-you have the same problem?
Best
need to see your scene structure
catoskogvoll
I have the same problem. All of the cloners appear in the live-view window, but when I do a proper render some of the cloners/instances does not show up. Here's the layer structure: https://www.dropbox.com/s/bq3s9nic43tux ... 4.png?dl=0
And here's what shows up in the render (not live-view, everything works fine there): https://www.dropbox.com/s/iv0nq0gajz3rl ... 2.tif?dl=0
I've tried turning the "Render Instances" on/off but to no avail... Any suggestions? Or is this a bug?
i7 2600k - 2x GTX780 SLi - 16GB RAM - 1200W PSU
it's a limitation for spheres. Also specified on some release notes. You shoul check off "Render Perfect". It doesn't produces triangles.
Also i see that you have not object tag over your animated objects. Don't you know that it's designed for faster renderings and interactive updates of objects? And why 2.06?
See this topic:
http://render.otoy.com/forum/viewtopic.php?f=30&t=45474
catoskogvoll
Awesome, thanks! I just skim the release notes :D I'm running 2.16.2 now, do you know when version 3 will be done?
catoskogvoll
aoktar wrote:Hi,
See this topic:
Is there any limitations to using spheres and metaball in Octane by the way? Just tested it now, and it doesn't work in either live viewer nor the render engine
No, only limit is triangle count. it's about total 19millions.
