OctaneRender® for Maya® 2.10 - 5.0 Linux [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Version 2014 64-bit on Linux operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® Beta License" priced at 199€
OCTANELIVE
  • New 2.10 engine.
  • Internal Motion Blur is implemented ("Subframe motion blur" feature is not removed, now you can choose between "Subframe motion blur" and "Octane Internal").
  • Octane render passes are implemented (they are still improving in ongoing Octane engine versions, so still subject to change in future). You must have the pass enabled if you choose it as current "Preview pass" for Octane Live-view mode).
  • New "Path termination power" attribute in "Direct lighting", "Path tracing" and "PMC" kernels.
  • New "Coherent mode" for "Direct lighting" and "Path tracing" kernels - lets render faster.;)
  • New "Use turbulence", "Invert" and "Gamma" attributes in Turbulence texture.
  • Fixed post processor bug sometimes caused rendering not working.
Installation:
DOWNLOAD
OctaneRender for Maya - v5.0 Linux (16.4MB autoinstaller file)
Yours,
The OctaneRender™ Team.
Just found a bug in Turbulence texture caused by new additions into it. Here is the QUICK FIX:
OctaneRender for Maya - v5.1 Linux (16.4MB autoinstaller file)
Download please the 5.1 quick-fix from bottom of header post, instead of 5.0.
matrix2012
Hi JimStar
On Linux, is the problem.
In Windows, I still have it tested tomorrow there for.
IES Light is not right.
I once attached screenshot.
To better show it.
Sorry for my bad english.
Thanks for the hard work
all the best
matrix2012
Next version HERE.
Return to “Autodesk Maya”
