OctaneRender® for Maya® 2.10 - 5.0 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
  • New 2.10 engine.
  • Internal Motion Blur is implemented ("Subframe motion blur" feature is not removed, now you can choose between "Subframe motion blur" and "Octane Internal").
  • Octane render passes are implemented (they are still improving in ongoing Octane engine versions, so still subject to change in future). You must have the pass enabled if you choose it as current "Preview pass" for Octane Live-view mode).
  • New "Path termination power" attribute in "Direct lighting", "Path tracing" and "PMC" kernels.
  • New "Coherent mode" for "Direct lighting" and "Path tracing" kernels - lets render faster.;)
  • New "Use turbulence", "Invert" and "Gamma" attributes in Turbulence texture.
  • Fixed post processor bug sometimes caused rendering not working.
DOWNLOAD
OctaneRender for Maya 2.10 - 5.0 (31.5MB autoinstaller file)
OctaneRender for Maya 2.10 - 5.0 Demo (29.8MB autoinstaller file)
Yours,
The OctaneRender™ Team.
Just found a bug in Turbulence texture caused by new additions into it. Here is the QUICK FIX:
OctaneRender for Maya 2.10 - 5.1 (31.5MB autoinstaller file)
OctaneRender for Maya 2.10 - 5.1 Demo (29.8MB autoinstaller file)
TBFX
Awesome! Now I just need to find some time to try everything out.
T.
Download please the 5.1 quick-fix from bottom of header post, instead of 5.0.
prodviz
Awesome, cheers Jim.
dionysiusmarquis
YES!
ciboulot
Waoh,
fantastic version Jim, many thanks. I have some questions though.
1. How do you setup the layer objectID? Does it have to be on some layers or to get an information by some nodes? WIll all the objects in a layer have the same color? For the moment, all the objects have different color (and I have to setup them as movalbe proxies)
2. How do we connect the 'hair color connect' to the shader?
Many thanks for your work, and your help
Laptop HP 8760w, I7, 16Go ram, Quadro fx3000m, Maya 2014, Octane 1.20a. Vimeo: http://vimeo.com/ciboulot/albums
solomon
JimStar wrote:Download please the 5.1 quick-fix from bottom of header post, instead of 5.0.
Thank you Jimstar!! this came at just the right time :)
Solomon W. Jagwe
solomon
Jimstar, a quick question ~ do you know what this error means?
// Error: line 19: No object matches name: dagMenuProc2008 //
and I am still getting that problem of Octane Materials suddenly not being recognized as octane materials when I open scenes created with previous versions ~ // Warning: Octane: Material "lambert1" is not Octane material, changing to "Gray"... //
Solomon W. Jagwe
solomon
Under Preview Pass ~ I see an entry called "Beauthy" was that supposed to be "Beauty" pass?
Solomon W. Jagwe
prodviz
Hi Jim,
the Gamma and Response curve in the camera is not updating here (same intermittent issue in previous version).
cheers,
Steve
Return to “Autodesk Maya”
