Error when converting poser->Octane.
seanlo
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\__init__.py", line 70, in Render
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 5108, in ShowSetupForm
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 183, in CreateNodesFromPoserScene
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 212, in ConvertMaterial
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 3494, in createNodeFromSavedTree
File "C:\Program Files\Smith Micro\Poser Pro 2014\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 3259, in createNodeFromSavedTree
WindowsError: [Error -529697949] Windows Error 0xE06D7363
This happens when i press octane render from poser 2012. I have tried to take out object by object, and all of them work when it is singular. However, when i combine them all together, it has that error message. The total polygon count is around 3 mil, i have 12 GB of ram, and am using a GTX 560.
Hi - how much VRAM does the GTX 560 have pls?
seanlo
Hi Paul,
Here's the specs:
GeForce GTX 560M 192 @ 775 MHz 192 Bit @ 1250 MHz
Codename N12E-GS
Architecture Fermi
Pipelines 192 - unified
Core Speed * 775 MHz
Shader Speed * 1550 MHz
Memory Speed * 1250 MHz
Memory Bus Width 192 Bit
Memory Type GDDR5
Max. Amount of Memory 1536 MB
Shared Memory no
DirectX DirectX 11, Shader 5.0
Transistors 1170 Million
technology 40 nm
Features CUDA, PhysX, PureVideo HD VP4
Notebook Size large
Date of Announcement 30.05.2011
You have 1.5GB VRAM. It looks like you are running out of VRAM whilst the plugin is generating Octane materials for the props and figures in your scene (check the Devices tab Octane Log as there might be a msg there). If you only have one video card, then Poser will be using some of that VRAM for it's OpenGl view. You can minimise that in Poser->Render->Render Settings->Preview, use SreeD, or set the Texture Display Preview Resolution to the minimum.
If you have a second graphics card (or user you on-board graphics) as the Windows display adapter you save a little more VRAM.
I think in general, 1.5GB RAM for Poser is not enough, because Poser figures have so many texturemaps and bump maps. I generally recommend 2GB as the lower limit, and 3GB as the preferred amount of VRAM.
seanlo
Yahoo it worked! Thanks for the instructions Paul.
I started deleting all unnecessary props for that render angle, and changed the OpenGL to SreeD (which i believe is the main culprit). It now renders fine. :D
Return to “Poser”
