Particles & Metaballs
Carrara (Integrated Plugin developed by Sighman)
tschwenke
Now, the plugin works well, but Particles and Metaballs doesn't seem to work for me. Is this a feature that isn't supported yet?
Regards,
Thomas
http://www.thomas-schwenke.me
Houdini 20.5 || Win11 || i7 + RTX3080
Sighman
Octane can only deal with mesh geometry. Carrara does not translate Metaballs into mesh to they can't be rendered by Octane.
Octane also does not have a way to render non-mesh particles. You can, however, configure Carrara to use mesh particles. These will be recognized by Octane.
Win8/64, I7-4770K (3.5Ghz) 24GB, GTX-980ti (6GB) / GTX-TITAN (6GB)
tschwenke
Thank you for your answer.
1) When I use a Particle Emitter and use, for example, diamonds, these particles will be rendered only when I make a Carrara render inside the window. Using the Carrara Animation Slider will not update the Octane Render Window. Do I something wrong?
2) How can I render fluids without using Metaballs in Carrara? Pycloid? Or can I convert Particle Metaballs into a mesh?
3) If (2) is not possible, wouldn't it be possible to use a Metaball algorithm and create the mesh for Octane Render? Metaball algorithm doesn't seem to be very complicated...
Regards,
Thomas
Sighman
tschwenke wrote:Hi,
Regards,
Thomas
I will need to investigate emitter animations.
I'll add meatballs to the list. Don't expect support for awhile. You should ask orion_uk how he did fluids in his animations.
Spectralis
Sighman wrote:I'll add meatballs to the list.
Could we have some pasta with that too?
ASUS Maximus VI Extreme, i7 3770k, 32GB RAM, 4 x GTX760 4GB, Win 8.1 x64.
Sighman
Grrr, damn auto-correct!!! :lol:
orion_uk
Sighman wrote:You should ask orion_uk how he did fluids in his animations.
Have talked with Thomas via PM but for the benefit of others..
Its quite a simple solution tbh...
I created the fluid sim in blender (you can also use realflow) and exported it as an obj sequence...
http://blenderartists.org/forum/showthr ... J-sequence
Then import in to carrara with...
http://www.digitalcarversguild.com/plug ... oductId=21
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
OctaneRender™ for Blender
Ds pro
OR Standalone V4
Poser Plugin
Sighman
I dropped a few metaballs into a scene and I was surprised to see them render in Octane. Apparently, Carrara does convert them to mesh. I don't know why you are not seeing them in your scene. I don't have any complex metaball scenes in my library so if you can point me to one I will investigate further.
Sighman
About Emitters
The plugin only supports emitting Objects. All others types, including Metaballs, are not supported. Here is a little clip demonstrating using a sphere primitive as an emitted object.
Balls.mp4
Particle Emitter
(6.54 MiB) Downloaded 8133 times
tschwenke
Thx alot for your answer. In fact, I mean the Metaball PARTICLE object :)
A simple Metaball object works fine, but I never use it.
So, is there any chance to see Metaball particle objects "in action" with Octane render? Would be great.
orion_uk pointed out a great way to do it with Blender or Realflow, but sometimes, I just want to stay in Carrara... quick and dirty :)
Regards,
Thomas
Return to “Carrara”
