OctaneRender™ for Blender 1.55 - 5.2 OSX [OBSOLETE]
The OSX version of OctaneRender™ for Blender plugin, 64-bit.
1. OctaneRender™ Server
The first part (server) should be run on the same computer as the second one..
  • Fixed bug: crash on Linux during changing of some material attributes.
  • Fixed bug: wrong dispersion coefficient loaded into server from Specular material.
Installation:
DOWNLOAD
Blender Octane Edition - v5.2 OSX (96.4MB autoinstaller file)
Aenima
No render server at....
Current users Blender and Octane preferences moved, same.
W10 x64 32GB, EVGA GTX960 - EVGA GTX1060 - OSX 10.12.5 - CORE I5 3.4GHz
Aenima wrote:No render server at....
All is OK. You are doing something wrong.
Be sure you have no blender.app or OctaneServer.app stored somewhere on disk (in locations other than standard "/Applications") when installing. OSX installer will see them as "already installed" during installation.
Aenima wrote:Current users Blender and Octane preferences moved, same.
Aenima
JimStar wrote:Installation:
Done. The problem is version mismatch but the two previuos versions worked well. I have some other blender build in different folders. After i moved them and reinstall your version Octane Blender working. Thanks for the info. Maybe put your version into a Blender Octane folder like on Windows? I think not i'am the only one who use several Blender versions because of the lack of addon updates and recent Python API changes.
:?: :?: :?[/quote]
If the emoticons means you dont know what i want to say: common method to solve app errors move/delete peruser preferences from library.
Done.
... I have some other blender build in different folders. After i moved them and reinstall your version Octane Blender working.
If you have the Mac applications being installed, additionally stored in different folders among the OSX computer - "Just run autoinstaller file" is not for you. It's for Mac users, who want to "just install" and does not store the application files manually outside the standard /Applications folder.
That's how standard OSX package installer works.
Aenima
Yep, but all other Blender versions are in subfolders in /Applications the only one Blender app in /Applications is your build. It works now but a bit weird why this version not workes as the two previous. Anyway thanks for your hard work.
The installer package was not changed from previous version, except just welcome text and license text were added.
One of packages being installed by the installer - the Octane-Blender app is the same named blob with the same attributes as native Blender release, as it is built from the same Blender sources.
OSX standard installer may behave not how you are expecting in your case (if you already have the same blobs in different place on the computer), as before installation it scans the computer for the same blobs as those being installed...
Aenima
Thanks, useful info for the future releases first i delete the existing then install. Thanks
Next version HERE.
Return to “Blender”
