OctaneRender® for Maya® 2.06 - 4.6 Win [OBSOLETE]
Maya® Version Requirements
This release will work with Maya® Versions 2013, 2013.5 / 32-bit & 64-bit, 2014 64-bit and 2015 64-bit on MS Windows operating systems.
HOW TO PURCHASE LICENSES
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 459€
Purchase an "OctaneRender™ for Maya® License" priced at 199€
OCTANELIVE
This is the quick-fix release.
  • New 2.06 engine.
  • Fixed scene format reading errors after changes of Node data structure.
  • Fixed issue led to shaders rendering mess in huge scenes.
DOWNLOAD
OctaneRender for Maya 2.06 - 4.6 (30.5MB autoinstaller file)
OctaneRender for Maya 2.06 - 4.6 Demo (28.7MB autoinstaller file)
Yours,
The OctaneRender™ Team.
yogurt
I've a 1.5 stand-alone version that use with maya between a mel script (it's the mel file scripted by you). This mel script run with the new version of octane? I mean for launch an animation this scritp it's ok?
Yogurt
abstractmedia
Awesome! I will test it out in a little bit.
abstractmedia
Hey JimStar,
This is my first upgrade since 1.5 because I was in the middle of a project. I just installed this 2.06 on both of the machines at our studio, and the first thing I get opening an old scene to fix some renders is an error message: "Errors have occurred while reading this scene that may result in data loss."
Opening the hypershade I see that a lot of the materials are not displaying correctly. After going through and re-attaching all of the image files correctly all of the materials are still rendering 100% white.
http://imgur.com/t3hm46a
The weird thing is that the textures are displaying correctly in hardware view, which leads me to believe the octane materials should be rendering the textures correctly.
I will continue to mess with it and let you know if I find anything.
prodviz
Cheers Jim.
Does this include motion blur in the IPR? (sorry, haven't tried this yet).
And are we able to import ORBX materials from Standalone?
cheers,
Steve
solomon
Hi Jimstar,
is the motionblur advertised in the video below, available in this build?
https://www.youtube.com/watch?v=gLyhma-kuAw
Solomon W. Jagwe
TBFX
Hi JimStar,
With the 2.06 engine it should be possible to remove the hard limit on emitter power so that we can go above 100000 but this limit still appears to be there in this version.
I doubt this limit ever really existed in the engine anyway as I have hacked .ocs files many times in the past to achieve this in the standalone and until recently I could do it in Maya by attaching a custom control attribute to the power attribute to overdive it but that little loophole seems to have been plugged.
T.
solomon
Hi Guys, is anyone else having trouble batch rendering with this build?
Solomon W. Jagwe
TBFX
solomon wrote:Hi Guys, is anyone else having trouble batch rendering with this build?
Yes there is a known bug. JimStar is onto it I believe.
T.
T.
Known to whom?
To make the bug known to me - I need at least a detailed description of it, and how to reproduce.;)
I even do not answer to one sentence reports "it does not work" if I see that it works OK for me...
Return to “Autodesk Maya”
