kitchen
acc24ex
lots of ies, need more optimisation, 6+ hours render time
MaTtY631990
nice ;) . What kernel you use for this render.
Thanks.
acc24ex
PT - 7-8 bounces I think..
daveyt
did you use all the gpus you have listed in your signature to render your image?
gtx 580 3gb gtx 660ti 3gb win 7 blender 2.65
FrankPooleFloating
Very nice. Just the right amount of "stuff". Excellent use of space. Two things: [1] It looks like you did an AO pass (perhaps with too high a distance) for some ambient shadows - and this makes your shadow around outlet and under AC unit look incorrect. [2] There does not appear to be tracks for balcony door to slide on. Slap some tracks in and tweak that AO and you are g-t-g. ;)
acc24ex
- yep I used all the cores, around 8 of them when I count in 580s and 590gtx (one 590 card has only one functional core)
- and yes the AO/dirt was a bit to high - wanted for it to look more realistic in the corners
- and the sliding doors.. great, thanks
.. this one is I think my "personal best" spent a lot of time tweaking, now I have a few more rooms to finish off
MaTtY631990
You have a multi gpu setup and took 6 hours to renders with PT. Did you render at bigger size than what you upload at.
Thanks.
acc24ex
- I think i rendered in around full HD - because of a lot of IES light it tends to be slower as well
- interiors are incredibly with any setup just ask gabrielle or guys with 6 Titana setups - all night long renders are common for interiors
- msybe I should try DL and fake bouncing light oldschool
- 590 gtx is maybe 10$ slower than the most expensive titan or 780 ti - it is ridiculous - and 590s still hold OK prices like 300-400 $ - yes it is ridiculous - but I would blame Nvidia for this - they didn't do anything to increase GPGPU speeds in the last 3 years
if you talk about prices, i'm with you, Nvidia is terrible :(
but you must consider that the 780 or titan are with one GPU only, you must compare the 590 with the orrible Titan Z in terms of power, obviously not comparable in term of prices ;)
anyway, very good scene, keep it up ;)
acc24ex
- no I am talking about technology also - 6xx series were slower than 5xx series - 7xx series were useless and expensive until Titan Z which is NASA expensive - so they waited for a couple of years to make something usefull - but with a such a price - there is no logical reason for you to buy one - instead buy a multi gpu box and put (plain) titans inside, they are cheaper than titan Z - come on
- it would be no problem if I made 5-10k$ *kilodollars per project - sure throw in a 4k$ Titan Z here and there - but people are cheap - someone will assume you job is worth 50$ - because all you produce are some fancy pictures - which are "computer generated" meaning exactly that a computer generated it - you were just playing with the computer as easily as playing a game (yes, after 7+ years perfecting your skills it might be as fun as playing a game at times, not when you have a job with a deadline)
- BTW, thanks for the positive feedback :)
Return to “Works In Progress”
