Materials not working
Moderator: BK
bpzen
Hi all,
I just downloaded teh latest version for DAZ, I am a Pose user looking to get to DAZ. Octane view port is working in DAZ however no materials are applied and when i click the Octane Materials button nothing happens.
Any ideas what I might be doing wrong?
thanks
Win 7 64bit, Titan 6 Gig and GTX770 4Gig, Intel 3.75GHZ, 24Gig RAM, Poser 2014 patched
linvanchene
edited and removed by user
bpzen
thanks i do have the check box selected to load from DAZ fails, however the figure is all grey as if ti was not selected and the materials Octane window will not open?
not sure whats going on i even unleaded DAZ and re installed and re installed plug in same results
bpzen
just to be clear, teh OcDS materials tab wont pop up at all nothing happens when i hit the button to view it
Spectralis
Have you registered the plugin and activated it with a serial? Have you downloaded the Live DB cache? Follow the instructions in the link below.
http://render.otoy.com/forum/viewtopic.php?f=44&t=38116
If you load a project that takes up more resources than your graphic card can handle then it won't open in the viewport. If you can't open the materials tab once the plugin is activated then this probably requires official support.
ASUS Maximus VI Extreme, i7 3770k, 32GB RAM, 4 x GTX760 4GB, Win 8.1 x64.
bpzen
yes its registered, db updated I loaded 1 v4 characters and open view port she is all white with no materials they are not transferring to Octane and when i hit the button to open the materials to try and do manually nothing happens.
DrHemulen
Did you actually run the "autogenerate materials" function in the Octane interface? What you describe is normal operation.
GTX 780, 6 gigs of VRAM - Win 7 Home Premium 64 bits
Spectralis
bpzen wrote:yes its registered, db updated I loaded 1 v4 characters and open view port she is all white with no materials they are not transferring to Octane and when i hit the button to open the materials to try and do manually nothing happens.
It sounds like you haven't downloaded the OR plugin materials. This can take quite awhile so if you haven't gone through this process you need to do it before the plugin will work. That's the only reason I can think of for why the "materials" page won't open even after registering the plugin. Please read the link I posted for a full run down of how to properly install the plugin and its materials.
If you've already done this then,as DrHemulen asks, have you tried autogenerating materials? There's a switch in the plugin that will do this automatically every time an object is loaded. If you're still unable to add materials then please, if possible, post an image of your plugin settings. Perhaps then we will be able to identify whether they are set up correctly.
Return to “DAZ Studio”
