Rendering overnight...
Proupin
...as if I could trust Octane to remain open till the next morning!! not a single time have I been able to leave an overnight render and see the results, ever... :(
jakchit
i let Octane render overnight all the time. what is the problem you are having?
win 7-64bit./Ubuntu 64bit 4gb ram. intel core quad q6600, geforce gt430 driver 260.89
steveps3
The dreaded live connection problem again. The sooner this gets dropped, the better.
(OS) Windows 7(64)
Proupin
no log so no way of knowing... this has happened even before LiveDB. I just find Octane closed.
jakchit
I leave Octane running for hours with no known issues. I do believe my hardware may overheat, but im not sure of that yet.
mbetke
YOu could run Rivatuner and its logging function to check the GPU stats. If something crashes/hangs7restarts you will see in the logs because they will end at a certain pont.
PURE3D Visualisierungen
ttaberna
I leave it overnight but just in case, as I live in Barcelona and is such a hot place, I leave a big fan running next to my computer for apporting fresh air to the graphic cards :mrgreen:
Rampage IV Extreme+i7 3920k+2x GTX580 3GB+2x GTX470
Proupin
I see most of you successful have two cards, display+render combo... Is this the case?
I will try Rivatuner as well... thanks!!
radiant
my two cents worth.
I have done countless around 20-15 animations/turntables
Most of them overnight with two or one card with no problem what so ever.
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
ROUBAL
I think that there are less problems with turntable animations, because Octane doesn't reload new frames.
I have had no problems with turntable so far, but as I said in other topics I have never been able to render a long real animation at night, because as soon as my internet connection has a failure, the rendering stops (Octane closes after each frame and open to reload the new frame, doesn't find internet connection and stops), and unfortunately it often happens (mainly at night for maintenance of the server or any other unknown reason).
