Has anyone noticed your GPUS throttling back when using the region render?
Mine drop back quite a bit when 3 sides of the region box touch the actual sides of the image.
Pull one side in (say 5% of image width) so it is only touching 2 sides and they run at full speed again. I wonder if this has anything to do with the feather edge that appears around the region?
I'm in the middle of a large render, so will check to see if this happens on other renders later.
Region render behaviour
I've noticed the same. The progress bar moves at normal speed but the ms/sec drop way down and it actually seems like it's not rendering at all. More weirdness though.. if the render region touches one of the borders I get a horizontal or vertical band being rendered. See my screenshot below:
horizontal band vertical band
Dino Inglese
CG Artist
Melbourne Australia
Octane build 4.04.0.145
CG Artist
Melbourne Australia
That is pretty weird! I had octane rendering a high res shot with region render touching two sides and it rendered outside the box, not inside. I noticed it throttling back via the msi temp/oc program. It does not throttle them back touching two sides but exhibits the other issue.
I can reproduce this problem here. I will try to fix it for the next release.MrFurious wrote:if the render region touches one of the borders I get a horizontal or vertical band being rendered. See my screenshot below:
