Hello, I get this error when trying to render an object with Reshapable proxy settings.
1 Created cube
2 Hit 3 on keyboard to show smoothed version of the object
3 Change geometry type to: Reshapable proxy
4 IPR Render
No problem at this moment when the "Octane Level" is 0.
Octane renders the cube as usual.
As soon as I use the slider to go to level 1 or 2 or 3, etc Maya crashes.
Fatal Error. Attempting to save in C:/Users/.....
Maybe I am doing something wrong.
Thank you in advance for your suggestions.
Snoopy
Fatal Error
Just in case anyone has the same problem.
I updated the Nvidia drivers and now it works.
I have a question,
when I have the IPR window rendering, if I use the "Insert Edge Loop Tool"
it freezes Maya and then crashes Maya completely.
Is that how is supposed to work? (I mean, I have to close the IPR render window, use the tool and then re-open the IPR Render window?
Does that happen to you?
Thanks in advance.
Snoopy
I have a question,
Thanks in advance.
Snoopy
