Skin textures don't work
LuvMultimedia
I have tried various skin textures in Poser on V4 and no matter what I do the skin textures will not show up in my Poser Octane renders. Everything else will load but not the skin texture. Can someone give me a step by step on how to get skin textures to load and render in Poser octane please? My email is [email protected] ...
WIN 10 64 | Geforce 970| 16 GB
Hi - are you able to provide the info requested in http://render.otoy.com/forum/viewtopic.php?f=45&t=40425 pls?
ThetaGraphics
When you say the textures don't show up, do you mean you just get a white model, or is the skin invisible?
If its invisible, check the displacement settings and disconnect it. (If you are in 2.0) I was running into this odd problem with the native Poser textures of my model when I first load her in. (Though importing an older poc would load in fine) Seemed to be something to do with the displacement being active yet at 0 depth. Disabling displacement import in the setup seemed to fix the issue... (I'm currently using a version of 2.05, has this glitch been fixed in 2.06, Paul?)
OctaneRender - DAZ Plugin
Win 10 64-bit | Intel 17-5930K 3.5GHz| RTX 3090 and GTX 1080 | 64GB RAM
wimvdb
Also try "Reconvert from Poser" at the mesh level in the materials group in the plugin
If you have loaded a figure with a texture attached, the plugin will use that texture set - even if you change it in Poser. To read the new set, use "Reconvert Materials for this Prop/Figure"
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
Return to “Poser”
