resume render
Dom74
Hello,
I just want to know if it's possible to resume a render ( like maxwell render ) :?:
I've rendered à scene with the default 16000 samples, it took over an hour to achieve, but there
is still some noise in the dark areas and some light/flashy pixels.
I have restarted a render with 32000 samples, it was better, but it's a loss of time to restart from zero.
Win7 x64 - 3DSMAX 2019 - 32GB RAM - 1080 TI
matej
No it's not possible ATM. Maybe in future releases.
cgmo.net
radiance
16000 samples is overkill, there must be something not set up right in your scene,
have you got any images/screenshots/renders ?
A resume from file option is planned for future versions.
Radiance
Dom74
I hope you are right.
That's what I was talking about, I know glass is heavy to render..
mode is pathtracing with 16 bounces ( 14 or 15 will do the trick, but don't change a lot render time ).
Dont know where make my signature, so :
GTX 480 / i7 980 / 12 GO RAM / W7 x64
bright pixels & grainy areas
franchus
@Dom74 I saw your image and it shouldn't take that long to get a decent image. You need to tweak your kernells one at a time. Also if you´re using small luminants (many lights) you might run into noisy results, increase their sample rate or choose an hdr (you can create your own hdr with hdri studio) a combination of sky hdr+sun is a great illumination solution that renders fast.
PolderAnimation
franchus wrote:@Dom74 I saw your image and it shouldn't take that long to get a decent image. You need to tweak your kernells one at a time. Also if you´re using small luminants (many lights) you might run into noisy results, increase their sample rate or choose an hdr (you can create your own hdr with hdri studio) a combination of sky hdr+sun is a great illumination solution that renders fast.
Beter late then never :). You are replying on a comment from 6 years ago (just that you know :)).
Win 11 | Dual RTX 5090 | AMD Ryzen 9 9950X| 192GB
