Aliasing issues
Lewis
Hi!
Is there a way/function how we could avoid jaggy (aliased) edges on bright surfaces (reflections on a car and bright black body materials) in Octane rendering?
I tried to cover it by adding some bloom and glare but no luck it's still very visible.
Lewis
http://www.ram-studio.hr
Skype - lewis3d
ICQ - 7128177
prodviz
Those look like overbright values (so values over 1).
You can pull these areas back in, in compositing apps, but it'd be cool to have a clipping/burn/shoulder type function in Octane itself.
juanjgon
Perhaps you can also try use lower power emitters and add more exposure time or ISO in the scene. I am not sure if this could help.
Lewis
Yes they are certainly over 1 (HDRI) but in LW native there is option called "limit dynamic range" which deals with that problem nicely. I hoped there is way to do it in octane somehow also.
thanks i+ll try lower value plus more exposure although i'm pretty high there also already ;).
Lewis
Skype - lewis3d
ICQ - 7128177
Lewis
Ok i dialed back black-body material for ceiling lights (it was 5.0 now it's 1.0), added bit more exposure and adjusted gamma but i still see same jaggy edges on lamps and reflections.
Hmm, what elee is there to try :)?
Lewis
Skype - lewis3d
ICQ - 7128177
juanjgon
Lewis wrote:Ok i dialed back black-body material for ceiling lights (it was 5.0 now it's 1.0), added bit more exposure and adjusted gamma but i still see same jaggy edges on lamps and reflections.
All the scene looks a bit crisp. Perhaps you could add a bit of DOF effect, or change the "filter size" parameter (for example to 2.0) in the kernel to try to add more antialiasing to the scene.
BorisGoreta
Render at double resolution and scale down.
3dworks
try the free OLMSmoother plugin - works really well in such cases.
http://www.olm.co.jp/rd/technology/tools/?lang=en
cheers
markus
Return to “Lightwave 3D”
