OctaneRender® for 3ds max® v2.03
Karba
Main changes since version 2.02
  • Fixed kernel hangs due to displacement mapping.
  • Fixed incorrect texture preview of bump mapped materials.
  • Fixed kernel failure when a mesh emitter with zero scale and non-zero translation is rendered.
  • vertex motion blur crash fix when object faces number is changing during frame duration.
  • incorrect octane viewport drawing fix (hopefully, I can't reproduce it, so had to fix it blindly).
Unfortunately, Ornatrix bug is not fixed yet, Ephere has some problem with license providing, so I am not able to test 3.x version at the moment.
DOWNLOAD
Installer http://render.otoy.com/plugindownloads/ ... p_2_03.zip (30MB ZIP File)
For network slave and daemon please download standalone installer here
http://render.otoy.com/forum/viewtopic.php?f=24&t=41123
Yours,
The OctaneRender® Team.
coilbook
Thanks I emailed video to octane support about incorrect viewport preview bug and i noticed it happens when Subsampling (right bellow motion blur) is set to more than 1 Hopefully it will help
Karba
coilbook wrote:Thanks I emailed video to octane support about incorrect viewport preview bug and i noticed it happens when Subsampling (right bellow motion blur) is set to more than 1 Hopefully it will help
Did you try this version? Does it have this bug?
kevinshane
Hi Mr.Karba
object sequence animation still can't produce any deform motion blur!(but can be render now in 2.03! in 2.02 it always crash!) Can I have you email? I can send u a test scene if u want!Thanks!
Shane
MSI GT70 laptop i7-3610QM+32G+GTX680M 4G
Octane Arch/Interior Viz Tutorials
http://www.kshane.com
oguzbir
Thanks... 'll be looking forward for the Ornatrix bug to be fixed.
My Portfolio
nildoe
Hi Karba,
I just installed 4* GTX780 with 6GB, and updated to 2.03, and whenver i open the octane viewport the render gets stuck at 1 Samp/pix.
If i press region render it suddenly updates like it should..and with region render on if i move the camera around the region render updates normaly...but as soon as i turn off region to render full frame it stays at 1 Samp/pix.
If i press render button, it renders ok.
can anyone please confirm this?
EDIT: I just used the same file on my laptop with 2.02 installed..and this does not happen..so it must be a 2.03 bug.
EDIT2: Just installed 2.02 on the system that had 2.03, and it renders fine..doesnt get stuck.
Nildo
Corei7, 6x GTX1070 (2 Inside and 4 in a CUBIX Xpander), 32GB Ram, Win10 64Bit Home, 3dsMax2017 64Bit, Octane for max 3 and LOVING IT!!!!
MSI GT72S 6QE Dominator Pro G win10Home, gtx 980m.
kevinshane
So am I! please fix that!
but if u get 1ms/s,u can try render with 3ds max frame buffer(shift+Q) ;)
User avatar (Default)
merid888
thank you for new versión karba, i'll test
twinsk8
Hi Karba I have a bug about displacement...Displacement objects are disapear in my scene:(
Thanx for helping
coilbook
I have not tried it yet. But in 2.02 sometimes it happens sometimes it does not. Mine went away after I turned subsampling down to 1. And I noticed it happens after a long render and when I open second 3ds max to start rendering another scene..(but i dont render until first one stops) Maybe 2 3ds max at once messes kernel up
Return to “Autodesk 3Ds Max”
