3D Gradient
Derya
I need a 3D Gradient inside a Cube, is this possible with 1.54.2?
yes,
but you need to use global coordinate system with help of projection nodes. try octane gradient and a XYZ projection (global)
Derya
Would be nice if you could you post an example.
there
gradient-xyz.rar
(70.1 KiB) Downloaded 602 times
Derya
Thanks Ahmet.
Derya wrote:Thanks Ahmet.
rica ederim
blastframe
aoktar wrote:there
Hi Ahmet,
I downloaded the file and gave your 3D Gradient Material a try. I would like to create a material that fades towards the center from the top and bottom. I removed everything but the diffuse, which is now set to a black and white gradient. Can you tell me why the gradient includes red (and how I can remove it without using an alpha channel)? I tried using a mix material, but this resulted in a color also. My C4D file is attached.
Thank you.
gradient-xyz2.zip
(97.34 KiB) Downloaded 312 times
no mistake, it's a bug. Fixing
