Exporter for C4D
ingostan
Well - i'll try if i can get any answer from anybody regarding the subject
WILL there be a new EXPORTER for C4D, as i can't afford to buy the plugin, but have to stay with the standalone and the exporter - alembic export is not an option as it cannot export materials
Best regards
Arne Fjord Rasmussen
hi,
there is no need for a new exporter, it works smoothly even with v2.02 ;)
you can use the exporter for the static geometry and the alembic exporter for animated cameras and geometry.
you can see alembic materials in standalone if you assign a polygon selection for any material with proper name and check the option in the alembic exporter.
ingostan
Thank you for the answer, i've have figured that out now - but it's a terrible way to do this - much work i think. Anyways - lokks like OCTANE is going to be a dead end for me then. Shiould have known before upgrading :-) :-) :-)
Thank you again for taking your time to answer me - i had a sense of talking into VOID :-)
Best regards
Arne
ingostan
bepeg4d wrote:hi,
Hi Again
Wll i thought i had figured it out.....but no - it renderes something i haven't asked for....
I know its much to ask but could you perhaps sketch a workflow for the following C4D rel 14 scenario
I matrix mograhp 3*3 with to spheres, one black and one red, and with a simulation "rigid body" tag.
i floor object with collider simulation tag.
One plane - as floor - with a floor material
One camera - close up of default view, 1920*1080p
100 frames
How would i go about, exporting this using exporter and alembic?
Thanks in advance
P.S. i tried with only alembic export and the animation keep exchanging the colours on the spheres with balck and red and back and forth and so on and so forth :-)
