Hair thickness not working
Rikk The Gaijin
Hi, I'm trying to export a group of hair from 3dsmax through Ornatrix alembic exporter, the hair are exported correctly, except the thickness. If I DON'T specify the thickness in max, and then I export the hair, they come in HUGE, and the Octane parameter to specify the default thickness doesn't work! :x
Here is the file, if someone wants to take a look... :(
eyebrows.zip
(244.35 KiB) Downloaded 123 times
Rikk The Gaijin
Anyone? :(
FooZe
Here is what this looks like for me:
This is with 2.02, default meters scale and hair thickness (0.0001).
Seems ok for me?
Rikk The Gaijin
The problem is you cannot change the thickness. It doesn't matter what value I put in, it always looks the same... Can you confirm that?
FooZe
Ahh, ok, sorry I thought the problem was that the hair was huge.
Yes I can confirm the default thickness does not seem to do anything for me either.
Is this the export with or without the thickness specified? (I'm guessing with?)
Rikk The Gaijin
FooZe wrote:Ahh, ok, sorry I thought the problem was that the hair was huge.
It is specified, yes, but even if I don't specify it, the hair come in huge, and the thickness parameter doesn't do anything. Can we have a "override thickness" option box in Octane?
Norman_Stansfield
Guys, is there any option to render hair directly from 3dsmax - by octane 2.0?
I mean standard hair and fur modifier.
Karba
Norman_Stansfield wrote:Guys, is there any option to render hair directly from 3dsmax - by octane 2.0?
use 2.02 version of 3dsmax plugin. there is an option in render settings - "standard hair&fur support"
