OctaneRender™ Standalone 2.02
abstrax
Hi all,
This is a maintenance update for version 2, fixing a bunch of issues reported on the forum.
Changes since version 2.01:
  • Added aspect ration lock to 2D transform, 3D transform and scale nodes.
  • Replaced shared geometry import preferences with two separate sets for OBJ and for Alembic files. The old settings will be lost so you have to set the new ones again in case you didn't use the default settings.
  • Replaced command line argument --script-args with --script-arg which can be specified multiple times and allows you to pass multiple arguments, which can be accessed via arg[n] in Lua.
  • Changed the behaviour in numeric fields: A left click (or right click) will switch always to edit mode, while a left drag will change the slider value (if there is one).
  • Fixed keyboard focus on numeric edit fields (i.e. iterating through the fields via tab should work again).
  • Fixed a displacement corner case that was resulting in black borders around triangles.
  • Fixed kernel fail in case a scene contains only image texture nodes without an image.
  • Fixed bad convergence in direct lighting kernel, when glossy materials are used (see http://render.otoy.com/forum/viewtopic. ... 34#p191734).
  • Fixed internal image size check which resulted in some missing images.
  • Fixed incorrect report of texture usage (see http://render.otoy.com/forum/viewtopic. ... 44#p192644).
  • Fixed out-of-memory problem in case of animation rendering via Lua (see http://render.otoy.com/forum/viewtopic. ... 91#p192691).
  • (Hopefully) fixed the "App Nap" problem with the net render daemon and slave on Mac OS 10.9. The slave and the daemon will not appear in the dock anymore only in the terminal.
  • Fixed a bug in the net render daemon that didn't stop the slave correctly if the master just disconnects.
Download
Windows
- 64-bit installer
- 32-bit installer
Mac OS X
- 64-bit installer
Linux
- 64-bit archive
Happy rendering,
Your OTOY NZ Team
emihich
Thank you !
prodviz
Cool, cheers for the update.
Hope the depth cap and animation .exr output format are in there :D
Oh, and .exr's appearing darker in Nuke and Photoshop, compared to the Standalone view.
cheers.
hi NZ team
A BIG thanks for the constant update :)
the 'app nap' issue under maverick it's solved, great!!!!
thanks also for the separate scale settings for obj and alembic, very useful for my workflow ;)
matej
Thanks for the update guys!
unrelated note:
I love the random color texture addition in 2.0 - a small thing that makes life so much easier. :D
cgmo.net
manalokos
abstrax wrote: [*] Changed the behaviour in numeric fields: A left click (or right click) will switch always to edit mode, while a left drag will change the slider value (if there is one).
This is still not good, left click should behave like left drag, only right click should switch to edit mode.
The new interface is a bit more confusing, everything looks the same and it occupies more space.
Filipe
Synthercat
I am with you on this Manolakos
Εγραψες!
Linux Mint 19.3 | GTX-1080Ti | AMD FX-8320 (OCed 4.4GHz) | 16GB RAM
resmas
Thank you. Textures loading problema is gone :D
All the best to you.
cheers
resmas
i7-2600k | SSD Vertex 3 | WD Velociraptor | WS Revolution | 16GB Ram HyperX | PSU LEPA G1600W | 3 X Asus GTX590 |
https://pt-pt.facebook.com/arq.resmas
prodviz
Cheers for the depth lift to 2048 in Path Tracing.
Just PMC to go ;)
Seekerfinder
EDIT: FOUND THE ISSUE: Rounded edges are on by default on existing materials - SHOULD THIS BE?
This has possibly been covered before but please help either way!
I am getting artifacts in 2.x that I did not get in 1.5x with the same file / geometry.
Best,
Seeker
