1.2 Vs 2.01
gabrielefx
results are printed on the info bar
no movable proxy, no displacement, no fur, no traps for both scene/kernels
1.2 Max 2012
2.01 Max 2014
PT 12 bounces
4XTitans
regards
ltchest
& how fast is the render when you hook up the other workstation as a render slave ? ;)
....it is sad though, to see this performance hit even when the scene is not doing anything beyond what you could already get from 1.2
Win7 64bit. i7 3930K 4.2Ghz.32GbRam. GTX670(4Gb)+2xGTX580(3Gb) | 3xGTX780(3Gb). 337.88. 1200W. (+ 5 x i7 2600 nodes).
RobSteady
Is the white balance the same?
mykola1985
GabrieleFX, i understand your frustration...
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
MaTtY631990
Try to remember that even if you don't use any of the new features, you still get slow performance. They are doing their best to recover some of the performance lost.
nagboy
Would it not be possible to have multiple kernels so the one that is used is the one with the exact features needed. It surely can't take a long time to update the code running on the GPU.
Return to “Autodesk 3Ds Max”
