Displacement not working?
ASyme1
For some resaon I can't load anything into the displacement channel. Worked before. Same version. Anyone else having this issue?
Alec
Alec Syme
http://www.fuseanimation.com
-Gigabyte X79-UP4 - Intel i7 3930 3.4 - Windows 8.1 Pro 64bit - EVGA TITAN X7 - 32 Gigs Corsair 1600 4 channel RAM -
ASyme1 wrote:For some resaon I can't load anything into the displacement channel. Worked before. Same version. Anyone else having this issue?
Alec
First you should create a displacement node, then place a image to them. or you can use a c4d shader in displacement.
ASyme1
I was using them fine a day or two ago. Today they don't work. I'll send you a screen grab tomorrow. Very odd. I noticed you mentioned a problem with displace and emitter in the same scene? Could that be it?
Alec
Alec Syme
samvac
Hi there, I'm having the same problem, just cant get displacement to work. did you have any luck in getting it to work :)
be sure displacement is enabled in material. Default is off
