For some resaon I can't load anything into the displacement channel. Worked before. Same version. Anyone else having this issue?
Alec
Displacement not working?
Alec Syme
http://www.fuseanimation.com
-Gigabyte X79-UP4 - Intel i7 3930 3.4 - Windows 8.1 Pro 64bit - EVGA TITAN X7 - 32 Gigs Corsair 1600 4 channel RAM -
First you should create a displacement node, then place a image to them. or you can use a c4d shader in displacement.ASyme1 wrote:For some resaon I can't load anything into the displacement channel. Worked before. Same version. Anyone else having this issue?
Alec
I was using them fine a day or two ago. Today they don't work. I'll send you a screen grab tomorrow. Very odd. I noticed you mentioned a problem with displace and emitter in the same scene? Could that be it?
Alec
Alec
Alec Syme
be sure displacement is enabled in material. Default is off
