Ok, here is the list, have also includes the old RC8 changes.
FIXED:
- Animated shader values will work with motion blur.
- Skip rendered frames will work again. For multiple images, all images must be existing to skip a frame.
- The use of the SDK 1.55 will support GeForce 7.xx cards. You maybe have to update your current driver to get the plugin working.
- The render region will work on all views.
- The render property for all passes can updated over the Octane menu with "Update Render Properties".
- "Distortion" parameter added in the ThinLens_Camera shader.
- "Distributed Ray Tracing" parameter added into the Info Channel Kernel.
- "Bump and Normal mapping" parameter added into the Info Channel Kernel.
- "Wireframe backface" parameter added into the Info Channel Kernel.
- "Parallelism" parameter added into the PMC Kernel.
- Max samples can now be set to 256000.
MANUAL
- The on-line manual is available at http://render.otoy.com/manuals/Softimage/
- Please follow the installation instructions in the on-line manual.
- This version requires video driver 337.xx or higher.
