Round edges smoothing issues
mbetke
I get smoothing erros with very basic geometry.
See attachment in the window frame. I used smallest value in materials.
Do I need something to keep in mind with building geometry? I thought round edges will work the way I only do basic geometry and it should look right.
PURE3D Visualisierungen
lixai
hi mbetke.
usualy for me a value of 0.002 is working well, if you can't go lower than 0.01 then you need to increase the precision to be able to input 3 decimals from max settings.
hope this helps.
Core i7 860, ZOTAC GTX 580 - 3GB, 2 x GTX TITAN, 32Gb RAM
Chris
What unit setup are you using? Is the mesh scaled correctly?
________________________________________________________
Win 7 64 | 1x GeForce GTX Titan | AMD Phenom II X6 3.20Ghz | 16GB
cybernoid
You are not the only one seeing this issue. So far all my tests with rounded edges show similar artefacts even after screwing with smoothing groups. At first I wasn't sure if it was simply a limitation of the technique used which meant that you just have to make the bevel as small as possible to minimise the problem.
But looking at this video I suspect actually it's a bug in the 3dsmax plugin: https://www.youtube.com/watch?v=9RbvHBFQHAA
In that video the bevels get quite thick with no similar issues appearing.
I need to take a moment to take the same geometry from 3dsmax into the standalone to see if this problem disappears...
_________________
RTX 3090, Ryzen 5950x, 32GB RAM, Windows 10 64-bit
mbetke
I set up units properly. Was the first thing I checked.
a3d
it would be nice if the rounded edge value would be in a reasonable range.
(system units in mm, generic units).
if i try to realize a 0.3mm fillet i have to set it 0,0003 or something in that range.
not very nice to adjust.
Karba
mbetke wrote:I get smoothing erros with very basic geometry.
rounded edges work like a bump. you can't change you geometry. It is designed to simulate very small fillet. We will try to improve the accuracy.
Return to “Autodesk 3Ds Max”
