OctaneRender™ Standalone 1.55 [current 1.xx]
abstrax
Hi all,
This is another maintenance update for 1.5, fixing bugs reported for the last version.
Changes since version 1.54
  • Progress displayed in the status bar (for example for loading files) is now displayed in the Windows taskbar, too.
  • Any currently loaded Alembic files are locked, i.e. can't be overwritten by other programs. The reason we need to do this is, because we don't load the full file, but only that part that is needed for the current time. Changing the file contents while in use by Octane results in a crash.
  • Because Alembic files can't be changed anymore while they are opened by Octane, the reload button was removed from the scene node graph UI.
  • Fixed updates of the environment, if connected via linker node.
  • Fixed occasional crashes when pasting with CTRL-V.
  • Fixed possible crash in PMC kernel (see http://render.otoy.com/forum/viewtopic.php?f=9&t=40046).
  • Fixed crash when opening a node graph editor for node graph with empty name.
  • Small improvements in the Lua node item API:
    • octane.node.create() and octane.nodegraph.create() give more detailed error messages when creating a node fails.
    • Added a read-only property nodeType to node items, which only returns a valid number if the item is actually a node, and graphType for node graphs.
  • Fixed freezes while rendering with the animation rendering scripts (or any script which calls octane.render.start() shortly after a previous render finishes).
  • Made internal file name handling more robust when dealing with malformed server names (Windows only).
EDIT: Updated the Mac OSX build to run with Mac OS 10.10.
Download
Windows
- 64-bit installer
- 32-bit installer
MacOS X (updated on 22/10/2014)
- 64-bit DMG archive
Linux
- 64-bit ZIP archive
Happy rendering,
Your OTOY NZ Team
pixelrush
Its nice you keep fixing things but I hope we can have 'the' final 1.5 now :roll:
Octane v1.55
Tugpsx
Just when we thought it was safe to go back into the water! LOL Thanks for update. Will give this a spin.
solomon
thanks for the update :)
Solomon W. Jagwe
kavorka
Sweet, thanks for the update :)
smicha
thank you
FoolooF
Thank you for the update.
User avatar (Default)
merid888
thank you, i'll install right now :)
emihich
Thank you for the amazing release ,and also for fixing the bugs for us.
I am using ORBX files imported from my 3d aplication ,
3dsMax via Karba's plugin and love the consistency of the imported materials and even camera.
Is it possible to have the same materials and camera consistency for the Alembic
abc files ?
eric_clough
I usually use Octane for Rhino and it works beautifully.
I also do a lot of my modeling in MoI so then I use Octane Stand Alone ... but this is the question. Can I create a material data base in a template so that I can import an OBJ file in MoI that can be imported with the 'styles' so that when imported the materials are assigned to the correct objects ... or a template that include all my usual materials ready to assign to objects ???
thanks,
eric
Actually, I think I have answered my own question.
e
Win 8.1,16GB,i7,GeForce GTX760(4GB),(GeForce 334.89 driver, GeForce GT640(4GB) Dual 27" monitors
