Rhino Plugin 1.50 Setting Resolution [to make a movie]
linkindark6022
Why can not I set as the one that stand-alone kind of resolution I want? When I want to make a movie and octane use as a rendering of engine, I must wait until every frame 16.000.
I would like to know if there is a way to set these parameters.
I downloaded version 1.50
Thank you in advance.
To set the render resolution when rending via the Rhino Render panel (using Octane), set the resolution as you would do for a normal Rhino render (ie. Rhino->Render Settings->Resolution). To set the samples rendered for each frame, set this in the OctaneRender for Rhino plugin Settings panel under the Kernel options.
linkindark6022
Thank you very much! The Power of Sharing.. bye
Return to “Rhinoceros 3D”
