Revit 2015
Hi
If anyone has upgraded to Revit 2015, can you pls post here, or send me a PM, and I will send you a test link for the 2015 version of the plugin.
prehabitat
I was about to install 2015, however I had second thoughts as I am in the process of setting up my new workstation. I've decided to continue waiting on adobe to sort out my licence migration; then as per my original plan will make a fall-back image of the drive.
After the above is done I'll install 2015 and give you a shout - I don't want to dirty the fall-back image with 2015 until I've had a chance to test everything...
Win10/3770/16gb/K600(display)/GTX780(Octane)/GTX590/372.70
Octane 3.x: GH Lands VARQ Rhino5 -Rhino.io- C4D R16 / Revit17
avidia64
Send me a test link, please.
Win7x64/i7-970/24gb/gtx580/gtx titan/3dsmax2014,2015/Revit 2014,2015
I have the plugin compiled for Revit 2015, however there is a crash when checking for linked files - which I have escalated to Autodesk. Will hopefully have a solution in the next day or two.
JeffreyMcGrew
I'd love a test link. Only thing keeping us from 100% switching to 2015 is this plugin!
I have spent a few days trying to get the plugin running under Revit 2015, however if you have any linked files in your scene, Revit crashes. I cannot find a workaround to this (since the crash is happening inside Revit, not the plugin). I have reported this to Autodesk, and will need to wait until they get back to me before releasing the updated plugin.
Below is the link to the Revit 2015 installer. However there is a substantial limitation imposed by Revit 2015 that was not in 2014. That limitation is the the plugin CANNOT open the Viewport if you are viewing a 3d Perspective Window. To me, this is a serious issue - but I would like peoples feedback on this.
1.52.0.4
- Compiled against Octane 1.52
- The Revit transparency amount is now used for the Octane opacity when converting Revit materials to Octane.
- Added option to export to ORBX (in addition to OCS)
- Modifications to enable a Revit 2015 version of the plugin
http://render.otoy.com/customerdownload ... _Win64.exe
WestCAD
Downloaded link and received error message
Windows 7 64bit, I7 [email protected] GHz 12gb Ram, Quadro 600
Autodesk Building Design Suite Premium 2015
The '2014' is a typo - and should read '2015'. Which version of Revit are you on? The installer assumes Revit Architecture, which should be in Program Files\Autodesk\Revit Architecture 2015. Can you tell me which folder Revit installed into pls?
WestCAD
Hi Paul, I am using Building Design Suite 2015 (Revit 2015)
I have previously been using Building Design Suite 2014 (Revit 2014)
and Octane loaded and worked fine.(was loaded in Program Files\Autodesk\Revit2014)
Program is loaded in Program Files\Autodesk\Revit2015
Return to “Autodesk Revit”
