2 materials on the same object
turtles123
hello everyone!
in my scene i have this cigarette pack, all the graphics are not reflective( and i am using a diffuse material for that) but the logo is super reflective and with a bump.
i have tried to stuck on my pack 2 different materials with alpha, like i would have done with c4d standard materials.
and i have tried the octane mix materials, but i cant figure out how does it works!
pls help!
i did similar work recently, just try mix material with diffuse and glossy materials
hi,
you need a b&w map where, for example, the white is the diffuse material and the black the glossy part, and then assign the mask map to the 'amount' channel in the mix material ;)
turtles123
thx a lot beppe your replies are always helpful!
bloodyriton
I did this, but I also need to place a logo onto circular brush metal texture.
So I need to place the logo in a certain position and the circular brush metal texture in an other position.
How can I do this with only one mix material applied ?
kiwimage
Can't you mix 2 mix materials ?
Using the same principle for mixing them (B&W texture).
Titan Black + GTX 580-3go / Win 7 pro 64 bits / C4DR14 with integrated plugin / Blender / Octane standalone /
website : http://www.kiwimage.com
bloodyriton
Hi kiwiimage,
sorry for the late reply, but I was in holydays ! :D
Yes I think I can but how to move projection idenpendetely for the 2 materials when I applied it?
enigmasi
1. use the main material for box
2. use material which has bump and reflection and check "mix materials"
it should work this way
bloodyriton
Perfect !!!!
Thanks a lot
