Hi all,
It seems that when I rotate an IES light it stops working in the render viewport? At a 270deg (Z axis down) it seems to work, but not at any other angle...Any help would be most appreciated!
- Rich
Rotate IES lights?
what's the version of plugin? I suppose that you have 1.0 or so.
Plugin works different for ies mapping since some sdk versions has projection nodes.
this scene has rotating lights. Pls check projection node of ies imagetexture
- Attachments
- ies.zip
- (287.73 KiB) Downloaded 251 times
Thanks aoktar - I've isolated the lights and they seem to be emitting from the -Y value? Included an isolated file - is it something to do with a dodgy IES?
- Rich
- Rich
- Attachments
- Ies_Trial.zip
- (97.21 KiB) Downloaded 252 times
i can't investigate now, but every ies seems different. Also keep RX=90 in spherical projection. You can scale ies file with transform node's SY value
