Rotate IES lights?
-rb-
Hi all,
It seems that when I rotate an IES light it stops working in the render viewport? At a 270deg (Z axis down) it seems to work, but not at any other angle...Any help would be most appreciated!
- Rich
what's the version of plugin? I suppose that you have 1.0 or so.
Plugin works different for ies mapping since some sdk versions has projection nodes.
-rb-
Hey aoktar,
I'm on 1.51?
Cheers,
- Rich
-rb-
If anyone has any suggestions would be great as I've got a client demanding spots be on particular items from below and I can't do it! (Pesky clients!)
- Rich
this scene has rotating lights. Pls check projection node of ies imagetexture
ies.zip
(287.73 KiB) Downloaded 240 times
-rb-
Thanks aoktar - I've isolated the lights and they seem to be emitting from the -Y value? Included an isolated file - is it something to do with a dodgy IES?
- Rich
Ies_Trial.zip
(97.21 KiB) Downloaded 230 times
i can't investigate now, but every ies seems different. Also keep RX=90 in spherical projection. You can scale ies file with transform node's SY value
-rb-
Great thanks dude
- Rich
-rb-
Hi again - I've been trying a few IES files and for some unknown reason I think it was a bad file - no idea! Works like a charm now though, thanks for your time!
- Rich
