Octane Render 2.0? supported SliceRender
Elvissuperstar007
hi!
Octane Render 2.0 will work with render Slice Render?
description
Have you ever had a client asking you for a huge print? A rendering with dimensions bigger than 32768 pixels? Have you ever tried to set a size like this in the render ouput of Autodesk® 3ds Max®? SliceRender bypasses these limitations and handles the limits of 30000 pixels that JPG and Adobe Photoshop© have! Our plugin slices your big rendering in small parts and stitches them together afterwards. The rendered strips/slices/crops/buckets don't break the maximum of 30000 pixels in width or height so you can easily edit them in your favorite image editing software or give them directly to the printing company of your choice. You can also use SliceRender for panorama walls, video walls, photographic wallpaper,...
You have the fun, we slice your render!
http://www.zwischendrin.com/en/detail/248
kavorka
Not sure if this helps, but as of Octane 1.5 they "Increased the maximum render resolution to 32K x 32K pixels."
You still have to hold that image in your VRAM, so some projects have a limit in size due to VRAM limitations, but for less dense scenes, you should be fine.
ROUBAL
You can multiply the resolution with the camera shift : it doesn't move the camera but shifts in fact the "sensor plan" and doesn't modify the perspective. So you can render actually huge images ! The process is not automated, but easy and you can already do that in Octane for ages ! ;)
You can render 8x8 images, so increase by 64 the surface of your render !
Paulski
Shouldn't be too hard to make a little LUA script that does the same job.
