Troubles with Octane
fallen21
I encounter 2 troubles currently with Octane:
- 1st one since few months i'm not able to move the sunlight system (see attached files)
- I experienced since few weeks some very hard crash with Octane 1.29 (computer freeze, render crash, etc) i've noticed this problem when i use & re-use the same scene, my hardware is quite good driver up to date.
Erick
In order to move the "Daylight" (aka sundir), you simply move the light called "Daylight" directly in your Poser scene.
Usually (if things didn't change), the plug-in renames the very 1st infinite light in your Poser scene to "Daylight", which you then just move around. The values then get transferred over.
You can not move the "Daylight" directly the plug-in.
Hope that helps =)
Regarding the crash, this is the first report of such a thing with that release. Can you post your hardware specs pls as per the TEST thread.
fallen21
Thanks Erick didn't known that Octane was linked to the Poser's lights.
- 7
- 64 bit
- 32 GOs
- x3 Titans
- 335.23
- Poser 2014 10.0.2
- OctaneRender for Plugin version 1.29
config.xml
(1.07 KiB) Downloaded 263 times
Do you have SLI disabled?
samhal
fallen21 wrote:Thanks Erick didn't known that Octane was linked to the Poser's lights.
- 7
- 64 bit
- 32 GOs
- x3 Titans
- 335.23
- Poser 2014 10.0.2
Wow! x3 Titans!?
i7 6800K (6 core), 24 GB, GTX 1080 8gb, Titan X 12gb
fallen21
SLI disabled (any cards are connected to each others in fact).
Is the crash just happening with one scene? If so, can you send it to me pls?
fallen21
It happens on some other scenes, especially when i use them several times.
If you export the Poser scene to OCS or ORBX and load into Octane Standalone 1.29 (or later), do you get the crash?
Return to “Poser”
