I'm not sure, if this is a Blender or Octane issue:
There's the smooth checkbutton in the octane materials. But: Imagine a 3D version of the letter C (extruded text). How do I end up with a smooth version of the letters faceted, curved sides, but retaining the sharp edges of the letters between top and bottom and the sides as well as not having some strange smoothing across the flat top and botton (which should remain flat)?
Basically a bit like the flat/smooth button in the left menu of the 3D view.. which smoothes things while in edit mode/solid of the faces I marked with it etc ... but it seems octane doesn't care for it and purely works with this global material smoothing?
Selective smoothing?
You can also try using a smooth material and adding an Edge Split modifier.
i7 5960X | 64GB RAM | Win10 Pro | ASUS X99 Pro mobo | Chieftec 1250W psu
MSI GTX 780 Ti OC 3GB | 2 x GIGABYTE GTX 780 OC 3GB on USB risers | MSI GTX 750 Ti for display
Blender + Octane | C4D + Corona
Flickr profile: http://www.flickr.com/photos/kubicki3d
