Rendering finishes after 1 frame ( R15.057 / Octane 1.13 )
fuelnewmedia
Hi all,
When rendering a frame range, the Octane Plugin often finishes after the first frame and declares the job finished.
Anyone else having this trouble?
Thanks for your help & best regards :)
Hi there,
is it for 1.13c?
can you give me more info? is this occuring for a spesific scene or mostly?
What's your comp and os specs? Are you using multipass?
Can you post console output with logging?
fuelnewmedia
Hi aoktar,
Thanks for your quick reply!
Our specs look like this:
Software
Cinema 4D R15.057
Octane Plugin Version 1.13
Hardware & OS
Windows 7 SP 1
Dual Xeon E5 2660 / 32 GB / GeForce 770 4 GB
Render Settings
1280x720
Multipass: 1x Object Buffer, Depth Pass
Frame Range: 0 - 100
Direct Lighting / GI_DIFFUSE
Sadly there is no error log, as the plugin does not consider it to be an error :)
Octane only tells me: ***********VP RENDER FINISHED**************
Thanks in advance & Best regards :)
i sended a test version to you
fuelnewmedia
Hi aoktar,
no change with the plugin version you sent me.
This is octanes log:
APPLY VP SETTINGS kernel:1 enable:1 vpSettings:0x000000002194F340
**** FRAME 0 DOC:0x0000000042816780  SUB FRAME:0/1 nodes:64 links:0
Tried to access pin via an invalid ID P_EMISSION (31)
Tried to access null node pin
Can't connect node 'Texture Emission' (NT_EMIS_TEXTURE, 00000000112CCB00) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000000F7F3950)
Tried to access pin via an invalid ID P_DIFFUSE (23)
Tried to access null item
Node type 33 is either unknown, a linker or incompatible to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000000F7F3950)
Tried to access pin via an invalid ID P_SPECULAR (138)
Can't connect node 'RGB Color' (NT_TEX_RGB, 0000000042BC7240) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000000F7F3950)
Can't connect node 'Texture Emission' (NT_EMIS_TEXTURE, 0000000042B7D6A0) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000000F7F3950)
Tried to access pin via an invalid ID P_TEX_OR_EFF (147)
Tried to access attribute via invalid index 0
We can't evaluate items of a different version (version 0)!
--------------------------- EXPORT LOG ---------------------------
Export materials time= 1959.234 ms
Collect objects time= 80.707 ms
Meshes creation time = 9307.901 ms
Octane voxelization time = 0.067 ms
Sending to Octane engine time = 198.725 ms
Invalid image type 1 for node type NT_TEX_ALPHAIMAGE
Invalid image type 1 for node type NT_TEX_IMAGE
************ VP RENDER FINISHED **************
Thanks in advance for your help & best regards
can you try pls 1.14 or coming version if it's released when you read this message? I think there was a problem for multipasses
fuelnewmedia
Hi aoktar,
tried new plugin version 1.16, still the same bug with multipass animation rendering in picture viewer: Rendering finishes after first frame...
Best regarss,
fuelnewmedia wrote:Hi aoktar,
Best regarss,
Paul,
could you please give me a scene for checking?
fuelnewmedia
Hi aoktar & all,
I think i found the problem: When having a mixed material setup with C4D standard & octane materials, the rendering of an animation stops after the first frame. With a clean scene that contains only octane materials, the rendering works like a charm, even with Multipass object buffers enabled.
LG Paul
