When rendering a frame range, the Octane Plugin often finishes after the first frame and declares the job finished.
Anyone else having this trouble?
Thanks for your help & best regards
APPLY VP SETTINGS kernel:1 enable:1 vpSettings:0x000000002194F340
**** FRAME 0 DOC:0x0000000042816780 SUB FRAME:0/1 nodes:64 links:0
Tried to access pin via an invalid ID P_EMISSION (31)
Tried to access null node pin
Can't connect node 'Texture Emission' (NT_EMIS_TEXTURE, 00000000112CCB00) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000000F7F3950)
Tried to access pin via an invalid ID P_DIFFUSE (23)
Tried to access null item
Node type 33 is either unknown, a linker or incompatible to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000000F7F3950)
Tried to access pin via an invalid ID P_SPECULAR (138)
Can't connect node 'RGB Color' (NT_TEX_RGB, 0000000042BC7240) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000000F7F3950)
Can't connect node 'Texture Emission' (NT_EMIS_TEXTURE, 0000000042B7D6A0) to static pin 'unknown' (P_UNKNOWN, type PT_UNKNOWN) of node '' (NT_UNKNOWN, 000000000F7F3950)
Tried to access pin via an invalid ID P_TEX_OR_EFF (147)
Tried to access attribute via invalid index 0
We can't evaluate items of a different version (version 0)!
Export materials time= 1959.234 ms
Collect objects time= 80.707 ms
Meshes creation time = 9307.901 ms
Octane voxelization time = 0.067 ms
Sending to Octane engine time = 198.725 ms
Invalid image type 1 for node type NT_TEX_ALPHAIMAGE
Invalid image type 1 for node type NT_TEX_IMAGE
************ VP RENDER FINISHED **************
Paul,fuelnewmedia wrote:Hi aoktar,
tried new plugin version 1.16, still the same bug with multipass animation rendering in picture viewer: Rendering finishes after first frame...
Best regarss,
