What is the highest GPU temp you've reached
radiant
Hello,
Since I'm doing a 500 Frame animation in the new v5.
I was wondering what is the highest GPU temp you've reached while rendering in octane.
I remember when i just had my 285, i was rendering something and it reached 80C.
that was before i knew about fan control and i could control my case fans lol.
now it is at 40C ideal and 60C when rendering.
My 480 runs at 48-50 Ideal and the highest temp was around 85 Degrees.
But again now with all of my fan control i now get a 75 while rendering.
So what is your highest readings?
Radiant
Win8 Pro 64bit ULT|Intel Core i7 3930K|3.20 GHz|32 GB RAM|GTX 590|UD5 2011 socket||2x TB HD||Master Cooler HAF X||Blender 2.6||Maya 2012||Octane|
PhilBo
I've seen 90 C. GTX 470 baby.
Win7 64| Two GTX 470s | Phenom II 920 | 8 GB
Win7 32| GTX 260 | Athlon X2 5000+ BE | 2 GB
ROUBAL
Well, due to a problem with former version of EVGA Precision and ASUS SmartDoctor not compatible with Win 7, one of my two new GTX 480 reached 101°C for a short time just after installing the cards in my Cubix box.
After I installed the most recent EVGA Precision version, I got maxi 83°C on the warmest card with 25°C ambient in the room. The second card was 6°C below.
My most recent renders with 23°C ambient gave 71°C and 77°C for the two cards.
Fans speed is oscillating between 70 and 80% using the "Smart Cooling" feature with standard response curve in auto mode.
radiant
hmmm does that cubix box have good ventilation???
Bulwerk
I have a GTX 465. I am at like 86C!!! yeah i need to do some tweaking. Plus I am in a hot room of the apartment.
ROUBAL
@radiant : enough fans, but not enough space between the two graphic cards imho. So one of the cards doesn't receive much fresh air, and is 6°C warmer than the other one.
Duke_Arnout
105 degrees C on the 480.
The card makes the most awfull sounds then. The fan goes crazy then goes silent...
Then it's time to put the fan in the 90s
E6400 2x gtx 570 8gb ram xfx 680i LT windows vista 64bit
radiant
Duke_Arnout wrote:105 degrees C on the 480.
try and trade/sell your 480 with the 580 its the same price and it is as silent has the 285.
its pretty much how the 480 should have been like
Meta
97°c on my 470, wich is why, quite rare, I came to sell it and buy the 460.
Maybe I could have tweaked it and got some ° down, but the card pcb being 'open' the fan directed all the heat on the cpu right behind, then the whole pc temperature would rise wich I did not like much.... :)
Don't know who had the great idea of 'opening' the 470 pcb but it's not that great :/
Core i7 2600K @ 3,4 | 16 Gb Ram @ 1600 | GeForce GTX 670 | Win 8 64
Return to “Off Topic Forum”
