Problem with shift camera
alexos
I've got a scene where shifting the camera only works in the IPR and not in the F9 renders. Kind of baffled, it seems to work in other scenes, no idea what could be causing it... I'm attaching an image just in case.
ADP.
juanjgon
I am just testing it here and all works fine. I am going to need your scene (or any other sample scene with this problem) to see what could be the problem.
What version of the plugin are you using?
alexos
Here's the super-simplified scene. As for the plug-in, I'm still on 1.23.2 (but again, this is the only scene that's giving that particular problem)
Thanks!
ADP.
EDIT: changed the former 9.2mb, 40+ layers object to something MUCH simpler.
shift_TEST.rar
(5.72 KiB) Downloaded 258 times
juanjgon
I think that your problem is the render region. Shift feature is not compatible with render region yet. If you disable the render region all works fine.
alexos
juanjgon wrote:I think that your problem is the render region. Shift feature is not compatible with render region yet. If you disable the render region all works fine.
Ah! That simple, eh? Thanks!
ADP.
Return to “Lightwave 3D”
