Crash when Combining mix materials in C4D plugin
EdCast
I'm experiencing crashes when attempting to combine mix materials.
This is what I'm doing:
Mix material 1 has texture 1 and texture 2
Mix material 2 has texture 3 and texture 4
Mix material 3 has Mix material 1, and Mix material 2.
Combining the mix materials results in crashes for me.
How can I combine mix materials?
Win7 64bit
i7 3930k, 64G Ram
2 Titans
1 690
1.0 RC2?
EdCast
RC2, on C4D R14
Sorry forgot to mention
Win7 64bit
i7 3930k, 64G Ram
2 Titans
1 690
Can you try 1.07b? Rc2 shouldn't give this problem, sorry. Can you attach crash reports?
Problem may be on previews. To disable material previews is a way.
SVITAdmin
_BugReport.zip
(33.58 KiB) Downloaded 263 times
Just tested on RC two. using r15. Check Materials on. I had no issues creating a mix material from two other mix materials. Until i started playing with the float texture. Then a crash. Report attached.
Tried again and a crash immediately. Tried again with check materials off. Still a crash
1 Dell Z840 with 2x Titan XP's
2 Digital Storm Hailstorm/Win8/32GB/EVGA Titan x4
2 Server blades with 4 Tesla K80's
EdCast
Here my R14 bug report with RC2.
Loading a texture into the mix material seems to crash it.
_BugReport.zip
(30.6 KiB) Downloaded 236 times
Win7 64bit
i7 3930k, 64G Ram
2 Titans
1 690
EdCast wrote:Here my R14 bug report with RC2.
also i need your materials
SVITAdmin
In my case, they were just two paint mix materials from the LiveDB
what happens if you disable material previews?
SVITAdmin
aoktar wrote:what happens if you disable material previews?
It still crashed unfortunately. I unchecked both Check Materials and Material previews.
