I'm experiencing crashes when attempting to combine mix materials.
This is what I'm doing:
Mix material 1 has texture 1 and texture 2
Mix material 2 has texture 3 and texture 4
Mix material 3 has Mix material 1, and Mix material 2.
Combining the mix materials results in crashes for me.
How can I combine mix materials?
							Crash when Combining mix materials in C4D plugin
1.0 RC2?
Can you try 1.07b? Rc2 shouldn't give this problem, sorry. Can you attach crash reports?
Problem may be on previews. To disable material previews is a way.
Just tested on RC two. using r15. Check Materials on. I had no issues creating a mix material from two other mix materials. Until i started playing with the float texture. Then a crash. Report attached.
Tried again and a crash immediately. Tried again with check materials off. Still a crash
1 Dell Z840 with 2x Titan XP's
2 Digital Storm Hailstorm/Win8/32GB/EVGA Titan x4
2 Server blades with 4 Tesla K80's
Here my R14 bug report with RC2.
Loading a texture into the mix material seems to crash it.
- _BugReport.zip
 - (30.6 KiB) Downloaded 197 times
Win7 64bit
i7 3930k, 64G Ram
2 Titans
1 690
						i7 3930k, 64G Ram
2 Titans
1 690
also i need your materialsEdCast wrote:Here my R14 bug report with RC2.
In my case, they were just two paint mix materials from the LiveDBaoktar wrote:also i need your materialsEdCast wrote:Here my R14 bug report with RC2.
what happens if you disable material previews?
It still crashed unfortunately. I unchecked both Check Materials and Material previews.aoktar wrote:what happens if you disable material previews?
