Bump AND Normal maps
Huv
new user… and exercising myself to octane…
Using the plugin, and wanted to add a little bump on these strawberries… but no way, when a texture is already in the the normal maps slot…
Bugg or doing it wrong ?
Other exercise on an evermotion light challenge scene (standalone version) :
Thanks for your help :)
FooZe
Hi Huv,
This is by design. The normal map takes precedence.
The bump map will only work if there is nothing in the normal map pin.
Chris.
hi, as a workaround, you can use a mix material to mix one with normal map and a copy with bump map ;)
Huv
FooZe wrote:This is by design. The normal map takes precedence.
Hi, :)
Is this going to change as the plugin is still in beta… ?
Such mix can be done easily in vray… and cinema 4d…
bepeg4d wrote:hi, as a workaround, you can use a mix material to mix one with normal map and a copy with bump map ;)
I'll try that ;-)
