Hey Bazuka
Is a transparency map in Maya carried over to an opacity map in Octane like the color map is.
I applied an opacity map in Octane post exporting... saved the OCS file then rendered an animation and the color map came over throughout but the opacity map (not in maya shader) did not stay with the OCS
So I thought I would se if a trans map stayed with opacity and first try it did not.
Thought I would check with the master before getting too carried away : > 0
Peter
Opacity Map
- p3taoctane
Octane exporters works with flags, so refractive needs to implement additional flags for new features. Opacity flag is not exposed yet, so it is not possible to control.
I have made a request for this recently as well as a more flexible AO control.
However,some features are reachable within an export, such as defining the 3 base shaders, I dont think opacity is wired up.
prove me wrong and we have a problem less to worry about
Amiga 1000 with 2mb memory card
Thats wrong...[gk] wrote:However,some features are reachable within an export, such as defining the 3 base shaders, I dont think opacity is wired up.
Octane use the information in the mtl file and if there is a map_d texture, Octane use it as a opacity map.
Maybe there is a problem that the obj export from Maya don´t interpret it correct.
face
http://vimeo.com/user2509578
- p3taoctane
I just tried a trans map and no it does not go across even though the color map does
Peter
Peter
